Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 23
Transformer Practice Exam
    #11
    Jun 2022
    34
    coefficient of coupling
    A certain transformer has a turns ratio of 1 and a 0.85 coefficient of coupling. When 2 V ac is applied to the primary, the secondary voltage is
    A. 1.7 V
    B. 0.85 V
    C. 1 V
    D. 0 V
  2. #12
    Jun 2022
    34
    secondary voltage?
    The primary coil of a transformer is connected to a 60 V ac source. The secondary coil is connected to a 330 load. The turns ratio is 3:1. What is the secondary voltage?
    A. 2 V
    B. 20 V
    C. 180 V
    D. 18 V
  4. #13
    Jun 2022
    34
    primary winding
    The primary winding of a power transformer should always be
    A. open
    B. shorted
    C. switched
    D. fused
  6. #14
    Jun 2022
    34
    reflective load
    When a 200 load resistor is connected across the secondary winding of a transformer with a turns ratio of 4, the source "sees" a reflective load of
    A. 50
    B. 12.5
    C. 800
    D. 0
  8. #15
    Jun 2022
    34
    secondary voltage
    When a 6 V battery is connected across the primary of a transformer with a turns ratio of 8, the secondary voltage is
    A. 0 V
    B. 6 V
    C. 48 V
    D. 0.75 V
  10. #16
    Jun 2022
    34
    total flux generated
    What is the coefficient of coupling for a transformer in which 4% of the total flux generated in the primary does not pass through the secondary?
    A. 0.4
    B. 4
    C. 9.6
    D. 0.96
  12. #17
    Jun 2022
    34
    load resistance
    A transformer has a 1:6 turns ratio and a secondary coil load resistance of 470 . The load resistance as seen by the source is
    A. 1.3
    B. 7.8
    C. 78
    D. 13
  14. #18
    Jun 2022
    34
    induced voltage
    When the speed at which a conductor is moved through a magnetic field is increased, the induced voltage
    A. increases
    B. decreases
    C. remains constant
    D. reaches zero
  16. #19
    Jun 2022
    34
    flux density
    For a given wirewound core, an increase in current through the coil
    A. reverses the flux lines
    B. decreases the flux density
    C. increases the flux density
    D. causes no change in flux density
  18. #20
  19. rsgordineer is offline Junior Member Pro Subscriber
    Jun 2019
    Quote Originally Posted by Vysakh9292 View Post
    What kVA rating is required for a transformer that must handle a maximum load current of 8 A with a secondary voltage of 2 kV?
    A. 4 kVA
    B. 0.25 kVA
    C. 16 kVA
    D. 8 kVA
    8A multiplied by 2kV = 16kVA.
  1. Practice Exam Upgrades Summer 2019
    Last Post: July 17, 2019, 04:16 PM
  2. Has the practice exam been updated since the change?
    By Beaumont1188 in forum NETA Level 3 Exam
    Last Post: June 28, 2018, 10:32 PM
