Results 1 to 1 of 1
EATON Magnum DS with 1150+
    May 2017
    16
    Came across a number of Magnum DS breakers in service with Rating Plugs that do not match the Sensor Ratings.
    Eaton documentation states that CT's ratio must match the rating plug rating.
    Rating plugs state "Use only with (Rating) Sensors"
    I interpret this if you change one you must change the other(s) so both match.
    This seems to lower the flexibility factor quite a bit. Am I missing something?
    Was there a good reason for EATON to do this?
    Does anyone know what the protections results are if they are not matched?
    Thanks
    Pat
  1. Eaton Magnum DS secondary block pin/socket type
    By bec51392 in forum Electrical Testing Talk
    Last Post: October 28, 2021, 12:00 PM
  2. Ground defeat digitrip 1150+ on Mag Ds
    By will_lunsford in forum Electrical Testing Talk
    Last Post: December 6, 2020, 07:12 PM
  3. EATON Magnum DS Switchgear – CT Shorting Block Design Flaw
    Last Post: May 14, 2018, 06:41 AM
  4. EATON Magnum DS tripping free? Give this mechanism spring a check.
    Last Post: August 28, 2016, 06:33 AM
  5. EATON Magnum DS with Digitrip 1150+ showing "TRIP" on the display
    By keith63c in forum Electrical Testing Talk
    Last Post: May 25, 2016, 02:03 PM
