Kalbi_Rob
We took 2 25' extension cord and cut them in half. On one half we put banana plugs (neutral and hot leads), and the other end we bought some battery jumper cable clamps. This allows you to plug an extension cord in the middle and make extra long leads. Since DLRO uses a Kelvin Bridge, the lead resistance is taken out of the equation, and you can test any length of bus by yourself.
I always recommend the end you put the banana plugs on the male plug side, since you then make a nice suicide cord that you could easily put a fused switch on to power up 120Vac equipment if needed.
I can buy 25' extension cords at harbor freight for less than $25 with the 4 clamps. Unless you like spending $200+ on the AEMC or Megger leads.
