Results 1 to 10 of 16
Understanding power factor is easy when you relate it to beer!
    Aug 2014
    Capital City
    74
    Here is a classic analogy using beer that will help you to better understand power factor...
    Imagine you have a freshly poured mug of your favorite brew sitting in front of you.
    The drinkable portion of your beer is represented by Real Power (expressed in kW). Real Power may also be called Actual Power, Active Power or Working Power. This is what actually powers electrical equipment and performs useful work (in this case, quenching your thirst).
    Along with your brew comes a little bit of foam, and that foam just isn't going to do anything useful, so consider this undrinkable portion of your beer to be Reactive Power, represented by KVAR. This is the power that magnetic equipment like transformers, motors and relays need to produce their magnetizing flux. Think of the foam as a reaction from pouring the beer.
    The combination of drinkable beer (kW) and foam (kVAR) inside of your mug represents the Apparent Power, or KVA.
    Power Factor is simply the ratio of Real Power (kW) to Apparent Power (kVA) and is represented by the following formula: PF = KW / KVA.
    Using our beer analogy you could write the formula like this: PF = Beer / Drinkable Beer + Foam.
    For any given KVA,the more foam you have (the higher the percentage of KVAR), the lower your ratio of KW (beer) to KVA (drinkable beer + foam). Thus, the lower your power factor.
    The less foam you have (the lower the percentage of KVAR), the higher the ratio of KW (drinkable beer) to KVA (drinkable beer plus foam). As your foam (or KVAR) approaches zero, the power factor approaches 1.
    Tulsa,OK
    Beer power factor
    Very helpful!!!
    Aug 2015
    14
    kvar beer analogy
    this concept is best understood with a live demonstration. cheers!
  7. TheBreakerGuy is offline Junior Member Pro Subscriber
    Sep 2015
    kva beer
    Ha! That is very helpful.
    Oct 2015
    slight mistake
    i think you might have meant to say PF is the ratio of real power (kW) to apparent power (KVA)
    Aug 2014
    Capital City
    74
    corrected
    D'oh! Thanks for pointing that out desspino, I will make the change.
    Quote Originally Posted by deespino View Post
    Power factor beer
    Next time I'm talking shop with my Uncle, who did that for Edison in his early days, I'll ask him if it was because utilities don't like too much foam. I may get a weird look, but if he says yes, he gets a high five!
    Classic analogy, good post.
  15. cj65shelby is offline Junior Member Pro Subscriber
    Jan 2016
    Central Indiana
    I love this explanation.....See learning can beer fun !!!
    Feb 2016
    This is the best analogy I have seen. Thanks!
    Jan 2017
    Quote Originally Posted by randywright View Post
    I'll drink to that!
  1. Power Factor for New Mineral Oil
    Last Post: February 22, 2020, 05:12 PM
  2. Replies: 9
    Last Post: August 16, 2018, 02:28 PM
  3. Replies: 7
    Last Post: May 28, 2018, 04:21 PM
  4. Easy way to calculate transformer fault current
    Last Post: June 11, 2015, 06:40 PM
