I've got a few questions I saw on the exam recently:
1: Which oil test is not required on silicone transformer oil?
2: What is the best way to test a removable temperature sensor on a transformer?
- Meter & Loop check
-Meter & thermocouple tester
- Heater & Meter
-IR camera
3: Best type of motor to use if its going to be speed controlled?
-shunt wound
-induction wound
-series wound
-cant remember the 4th option
4: Circuit breaker time travel analysis, what causes it to take longer?
-Bearing wear
- can't remember all other choices
5: Surge arrestor lead cable in order to reduce impedance?
- short cable no bends (i chose)
- short cable w/ small loops
- short cable w/ big loop
- avoid sharp bends
6: Feeder breakers in a hospital with a 3000A 480V service that serves critical care have to have?
- Ground fault
- shunt trip
- zone interlock
-cant remember 4th option
7: which oil tests do you perform on HV oil switch?
-DGA
-IFT
-Di-electric strength (i chose this one)
-water content
6: what meter shows SF6 gas level
-density
-level gauge
-temp gauge
-can't remember
