SecondGen
What are the vacuum and pressure pickup settings? What size transformer?
Depending on what you have I would probably do it the same way. Set your pressure alarm down to a couple pounds and your vacuum alarm to zero, add nitrogen to get a pressure alarm, then relieve pressure to trigger the vacuum alarm.
You could also remove the gauge if possible and use fittings to attach your nitrogen tank to the gauge, just don’t forget to use the appropriate plug for temporarily plugging the tank opening where you take out the gauge!
