Jrmcritical
Hey Guys,
Just curious on what the rest of the electrical testing community thinks about conducting Insulation Resistance ("Megger") testing on isolated utility feeders or in some cases buss.
For Example: You are conducting preventative maintenance on a 4,000A service switchboard (less than or = to 480V) in Manhattan, NYC. Since the customer wants maintenance performed on the service switch, ConEd (the local utility) has been hired to "disconnect" the service in the street. Upon completion of maintenance, DLRO contact resistance testing, and an insulation resistance test of the isolated switchboard, would you megger the feeders going out to the street (assuming you confirmed they are deenergized and utility personnel are clear.)?
Coworker 1: "Yes, I see the feeders (or buss) as an extension of the switchboard."
Coworker 2: Never, that is strictly the responsibility of the local utility.
Personally, I have mixed feelings. I've done some testing on the side (haven't we all...) and my normal procedures are for me to see how the local utility has disconnected the service. If buss plates were removed, and there is a visible gap then yes, I'll conduct an insulation resistance test. If the utility workers had to use shims or cable boots, then I most likely would not conduct an insulation resistance test.
What would you do.....
