Kalbi_Rob
Pearson Testing Labs are pretty strict. They require you to empty your pockets and put everything in a locker, then pull your pockets out before you can go back to the testing area. The only items you are allowed is a laminated piece of paper, an erasable marker, and earplugs provided by Pearson. The exam calculator is a TI-36X (displayed on the screen), which is the same FE and PE engineers use on their exams which is a step up from the crappy one from previous years. It also allows for phasor and vector math if you know how to use it. Along with the two equation sheets.
One of our techs will make a cheat sheet to study prior to entering the exam, then once he sits down, writes down everything he can remember on the scratch sheet.
