Has anyone ever come across a pad mount transformer that has a larger than normal Schrader valve size? I came across one a while ago that our chuck wouldn't fit onto.
I have not found any hardware to fit this schrader valve.
We have done one of two options, first being just relieve the vacuum to atmosphere (not our preference) which is the recommendation from the manufacturer.
The second option is to take a poly bag and tape it to the end of the nitrogen output. Tape this bag around the relief valve and fill the bag up with nitrogen. As you pull the relief valve, continue to fill the bag with nitrogen and the relief valve will suck in nitrogen as you remove the vacuum. Unfortunately, neither method will pressurize the transformer, but you won't be taking a sample with a vacuum on the transformer.
Schrader Valves are not all the same size, just most are the 1/4" variety.
Dimensions
Schrader valves are classified by their material, diameter of intended rim hole, length, and shape.
TR-4, straight metal stem (8 mm dia.)
TR-6, straight metal stem (8 mm dia.)
TR-13, straight rubber stem (11.5 mm dia.)
TR-15, straight rubber stem (16 mm dia.)
TR-87, short 90° metal stem (10 mm dia.)
TR-87C, tall 90° metal stem (10 mm dia.)
and also:
TR 413, 0.453 in (11.5 mm) rim hole diam. 1.25 in (32 mm) long
TR 415, 0.625 in (15.9 mm) rim hole diam. 1.25 in (32 mm) long
TR 418, 0.453 in (11.5 mm) rim hole diam. 2 in (51 mm) long
TR 425, 0.625 in (15.9 mm) rim hole diam. 2 in (51 mm) long
The standard Schrader valve has the following threads:
External thread
Metric: 7.7 mm OD, thread root diameter is 6.9 mm × 0.794 mm pitch
Imperial: 0.305 in OD, thread root diameter 0.271 in × 32 tpi (threads per inch; thread density)
Internal thread (to accept the threaded valve core)
Metric: 5.30 mm OD × 0.706 mm pitch
Imperial: 0.209 in OD × 36 tpi
