Results 1 to 7 of 7
Best meter to keep on hand?
  1. TrapFlyVenus's Avatar
    TrapFlyVenus is offline Junior Member Pro Subscriber
    Dec 2018
    12
    Trying to buy a good meter that does it all for us. Amps,ground test, 1kv megger and anything else you guys can think of.
    Dec 2019
    Quote Originally Posted by TrapFlyVenus View Post
    I don't think there is anything that will meet this criteria. I may be wrong, but I have not seen anything that would be satisfactory. You would be better off getting specific meters for each application
    www.taifaengineering.com
  5. jbozarth is offline Junior Member Pro Subscriber
    Nov 2019
    10
    I would grab a Fluke Multimeter and a megger.
  7. rofo42 is offline Seasoned Member
    65
    A Fluke 1587 and a Fluke 381 will take care of the 1kV insulation tester, multi meter and amperage testing requirements. A ground tester will need to be a separate piece of equipment.
    Jan 2020
    Installation Tester
    A multifunction Installation tester like this sounds like what you are asking about:
    https://www.aemc.com/products/multi-function-testers/
    These are not as common in the USA but used quite often in Europe. It has an integrated ground tester, 1kV megohmmeter and common voltage current options and can generate a report. You can also use it to test tripping of ground fault devices. it will save your results and then you can generate a report.
    Jun 2017
    25
    Quote Originally Posted by jbozarth View Post
    This is what I use both Fluke and Megger i have yet to run into a devices that does all those functions and has the accuracy that is required.
    Sep 2019
    MI
    10
    I don't know of a meter that covers everything you are looking for. Even if one exists I would be cautious of the safety and reliability. Not to mention, the whole putting all your eggs in one basket thing.
    I like the Fluke 87V. I have also used the Fluke 787 because I needed voltage output for testing and calibration.
  1. watt-hour meter: finding revolutions per minute?
    By Bradfoxthelegend in forum NETA Level 3 Exam
    Last Post: June 24, 2021, 08:09 AM
  2. Klein Tools Clamp Meter Recall
    By madMAX in forum Safety and Arc Flash Talk
    Last Post: January 31, 2021, 10:31 AM
  3. Watthour meter testing
    By Larry5443 in forum P&C / Relay Testing Talk
    Last Post: November 20, 2019, 06:33 PM
