Results 1 to 1 of 1
NETA Level 2 Study Tips December 2019
    Nov 2019
    12
    I recently took my level 2 along with a few other guys where I work. Not everybody passed but here is what was on our tests. Some of this may already be posted in other threads but other parts are new:
    Test focused mainly on math, transformers, relays
    Picture of main tie an asking if a switch will open when tie opens
    Relay numbers, what does this device do?
    Basic ANSI device numbers (know 21,27,32,50,51,52,59,87)
    One or two questions on mechanical relays operation such as “pick up current was low, what setting needs to be
    moved” etc.
    Differential relaying theory (basics)
    Know Shading coils
    Not much on safety, two confined space questions
    What defines a confined space?
    Can someone attend more than two manholes?
    “When is it acceptable to wear cotton clothing?” In regards to voltage levels
    Electrical rubber glove classes (max use voltage) and inspection dates
    One guy said no questions on 1910.137
    Know PCB reporting requirements - 10 pounds
    protective ground sizes and functionality
    LOTO process
    How much torque at this horsepower?
    Basics of thermography (emissivity etc)
    Looking at infrared image, no temp points, just scale. Approximate the temperature in the area indicated.
    600a real power with theta angle, what is the reactive power?
    Know how to find kVARs
    Know how to find power factor
    Know your power triangle in general
    CT polarity and gf scenarios, what is the secondary current, is this wired properly
    Bar type ct picture in a switchgear with an arrow asking what is this
    A few pictures with items like a CT being pointed to and asking what it is
    Circuit breaker one-line symbols
    Where to test on a switch for contact resistance, point 1 and 9
    Basic kirchhoff law, proportional calcs
    What color sticker for acceptance? white
    Diagram with open contact on top and closed contact on bottom, type c or class c
    Voltage drop across resistors in series and parallel
    Total resistance calculations in very basic circuits
    What is the total inductance? Series and parallel
    Know contact resistance and how it works
    Ductor readings - which one is acceptable?
    Generator testing
    One line drawings in general
    General knowledge of power factor testing
    Ground testing (know the values in ohms)
    Understand grounding principles
    One or two questions on fiber optics
    Know the value (15%) in which fuses fail
    Read your MTS and ATS! Quite a few questions lifted straight from those two.
    Know medium voltage testing requirements
    NEMA enclosure ratings
    Familiarize yourself with anti pump characteristics and blow out coils
    % allowable for transformer winding resistance
    What properties transformer oil shows when it has arced / broke down?
    Know the uses of meters and the leads associated
  1. NETA III TEST Jan 2019
    By cbrazzil in forum NETA Level 3 Exam
    Last Post: March 1, 2021, 10:35 AM
  2. NETA III Test April 2019
    Last Post: May 1, 2020, 07:13 AM
  3. 18 study tips for the NETA Level 4 exam
    By Test Tech from DMV in forum NETA Level 4 Exam
    Last Post: September 12, 2017, 02:05 PM
  4. NETA level 4 recommended study tips
    By ruel guanzon in forum NETA Level 4 Exam
    Last Post: November 18, 2016, 03:39 PM
