In reviewing a MV Cable Test Report is there an industry standard to compare the resulted values to verify if the values provided in the report are acceptable. For example looking at a MV test report for a Hi-Pot test of MV conductors stepped over time 1 - 6 then Final for 15min. at maximum values. Also if there is a difference between phases and ground would the standard list acceptable delta between phases that would be acceptable. thanks.
