What type of abrasive material is used for abrading cable insulation?
Anyone have an answer to this
Aluminium oxide sandpaper strips is what we used back when I was a cable splicer.
After sanding, we cleaned thoroughly with alcohol and we applied 3M silicone grease.
That was many years ago, so things may have changed.
https://www.sparkyabrasives.com/supe...50-yards-long/
Another thing we did was to sand the conductor dull with the same aluminium oxide tape and used a product called Penetrox.
Because aluminium oxidizes in about 1/10th of a second, to make a good contact, we applied the Penetrox on the aluminium conductor, sanded it with the aluminium oxide sandpaper and crimped it right after.
Again, I am not sure if this method is still in use.
http://www.krimp-dsm.com/wp-content/...ccessories.pdf
https://www.tessco.com/product/4-oz-...rox-a-13-25478
Important note: Penetrox was for the conductor, not the insulator!
We applied 3M silicone grease to the insulator.
did you have this on your NETAIV exam?
